I am converting VCD to DVD (with plenty of help from this forum).
I converted 44,1 mp2 audio to 48 mp2 as per instructions using BeSweet GUI. Now TMPGE DVD author tells me that the new file labelled "mp2" is not mp2 or any other allowable format.
Searched forum, no answers.
Over to you, wise and toothless ones. What gives?
You didn't need to convert using Besweet - you could have just dropped it into TMPGEnc DVD Author as is and it would have converted it for you.
If in doubt, Google it. -
I don't think that's true for earlier versions of TMPGEnc DVD Author. I use 1.6 now and it works, but I seem to remember trying to put a VCD mpeg in at least one of the 1.5 versions and it wouldn't take it.
I did this a few months back using this guide;
https://www.videohelp.com/guides.php?link=436
Very fast and easy.
my pc wont recognize my sony handicam dcr-hc21
By J.Frost in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2009, 23:27 -
dvd fab wont recognize target burner drive
By lauraji in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 00:34 -
convertx wont recognize avi
By brdhsby5 in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 17:01 -
comp wont recognize older cd's & dvds
By lawzfeehily in forum Software PlayingReplies: 6Last Post: 12th Sep 2007, 16:56 -
DVP-5982 Wont recognize Extern Hard Drive?? Any help?
By ebayork in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jul 2007, 22:14
