hello, i have a .img file(its' a dvdr by the way) and i tried to use dvd decrypter to burn it, but the problem is when i tried to load the file, i recieve a message box saying "invalid or unsupported image file format"
so are there any ways i can fix that problem or any other problem that burn .img file?
thankx u
alcohol 120%
recordnow max
nero
gear
dvd decrypter i thought -- try changing it to iso"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
change it to iso
EX: blade.iso
and burn with dvd decrypter"What It Do"
Huh ????? -
Disk Juggler
Not bothered by small problems...
Spend a night alone with a mosquito -
what is the difference? for example to play dvd film files on my xbox, I just change the file name suffix from .iso to .img and they play as is on xbox media center of the xbox hdd
There's no need to change it to ISO.
Just scroll down to ALL FILES when loading the image in DVD Decrypter ISO Write Mode.
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 14:25 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 13:41 -
Writing fail with Img Burn
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 04:02 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2008, 23:11
