  1. nero vision express fails after the trancoding part, when i try to make a photo cd, tried again today and get the same problem even after ive updated the program to the latest version
    here the log file, says something about not enough memory????
    [15:04:23] NeroVision NeroMediaCon.dll: ------+---------+--------+--------
    [15:04:23] NeroVision NeroMediaCon.dll: 0 | 1 | 1 | 1
    [15:04:23] NeroVision NeroMediaCon.dll: total : 2
    [15:04:23] NeroVision VCDEngine::MPEGConverter: converting to MPEG done: size=36 sectors, playtime=0 CD-frames (0.000000 secs)
    [15:04:23] NeroVision 1A23-0009-5030-2488-9428-7211
    [15:04:23] NeroVision Windows XP 5.1
    [15:04:23] NeroVision IA32
    [15:04:23] NeroVision WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 28/05/2003 18:53:46
    [15:04:23] NeroVision ahead WinASPI: File 'C:\Program Files\Ahead\NeroVision\NeroFiles\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 17:33:44
    [15:04:23] NeroVision Nero API version: 6.3.1.25
    [15:04:23] NeroVision Using interface version: 6.3.1.11
    [15:04:23] NeroVision Installed in: C:\Program Files\Ahead\NeroVision\NeroFiles\
    [15:04:23] NeroVision Application: ahead\NeroVision
    [15:04:23] NeroVision Recorder: <PHILIPS DVDRW1208> Version: 1.34 - HA 1 TA 0 - 6.3.1.25
    [15:04:23] NeroVision Adapter driver: <atapi> HA 1
    [15:04:23] NeroVision Drive buffer : 2048kB
    [15:04:23] NeroVision Bus Type : default (0) -> ATAPI, detected: ATAPI
    [15:04:23] NeroVision === Scsi-Device-Map ===
    [15:04:23] NeroVision DiskPeripheral : Maxtor 4D080H4 atapi Port 0 ID 0 DMA: On
    [15:04:23] NeroVision DiskPeripheral : Maxtor 6Y040L0 atapi Port 0 ID 1 DMA: On
    [15:04:23] NeroVision CdRomPeripheral : PHILIPS DVDRW1208 atapi Port 1 ID 0 DMA: On
    [15:04:23] NeroVision CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
    [15:04:23] NeroVision === CDRom-Device-Map ===
    [15:04:23] NeroVision PHILIPS DVDRW1208 D: CDRom0
    [15:04:23] NeroVision AXV CD/DVD-ROM F: CDRom1
    [15:04:23] NeroVision =======================
    [15:04:23] NeroVision AutoRun : 1
    [15:04:23] NeroVision Excluded drive IDs:
    [15:04:23] NeroVision WriteBufferSize: 74448896 (0) Byte
    [15:04:23] NeroVision ShowDrvBufStat : 0
    [15:04:23] NeroVision BUFE : 0
    [15:04:23] NeroVision Physical memory : 511MB (523760kB)
    [15:04:23] NeroVision Free physical memory: 6MB (6820kB)
    [15:04:23] NeroVision Memory in use : 98 %
    [15:04:23] NeroVision Uncached PFiles: 0x0
    [15:04:23] NeroVision Use Static Write Speed Table: 0
    [15:04:23] NeroVision Use Inquiry : 1
    [15:04:23] NeroVision Global Bus Type: default (0)
    [15:04:23] NeroVision Check supported media : Disabled (0)
    [15:04:23] NeroVision 26.9.2004
    [15:04:23] NeroVision NeroAPI
    [15:04:23] NeroVision 15:04:15 #1 Phase 90 File APIProgress.cpp, Line 273
    [15:04:23] NeroVision Buffer Underrun Protection activated
    [15:04:23] NeroVision 15:04:16 #2 Text 0 File ThreadedTransfer.cpp, Line 505
    [15:04:23] NeroVision Tried to get 72704 KB of memory
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I'm no expert but by looking at it it seems all your ram is being taken up. Close everthing you have running and try again. If that doesn't work (i'd do this anyway) reboot then go to start>all programs>accesories>system tools>system information .
    Scroll down and see what the available physical memory is. It should be around 200mb or more with 512mb of ram on your system. If it isn't you have too many start up programs running in the background.
  3. i see what you mean ill try doing a clean boot (disabling eveything in msconig)
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Don't disable everthing, some of those startups are required. Go here: http://www.sysinfo.org/startuplist.php
    Here's another good site: http://www.blackviper.com/WinXP/supertweaks.htm
