Here is what I would like to do. I do some minor DJ'ing at parties, I would like to use my ATI AIW 7500 card to send video such as Winamps visualization screen to a TV without the rest of winamps playlist and player or my Karaoke program to send just the words to the TV while at the same time maintaining my players controls on my monitor. Does anyone know if this can be done?
Thanks, Dave
If the parts of the program screen that you want to move can be dragged seperatly from the rest of the screen you can set up with an extended desktop and just drag the parts that you want to that part of the desktop wich would be your tv. ATIAIW 7500 can do this. If your program screen cant be split apart try running the program twice or side by side and drag a built up play list to the second half of the extended desktop for public viewing, while you build another playlist to be swapped when the first is over. I know that this can be done with an older version of media player but I don't know what version.
You may have to tweek the settings to get it to work and when you do get it to work take notes(it will be em bare ass ing if you can't get to work in front of a group) so I would say that you should practice a few times before you count on it in public!IS IT SUPPOSED TO SMOKE LIKE THAT?
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 16:08
