...folder? Hi all, just curious if I could somehow create an .ISO with "some" program from a VIDEO_TS folder with my movie files?
The reason i'm trying to do this is because I just spent about 3 days using the big three to backup my star wars discs and I'm seeing the subtitles are way out of whack. I have never seen this before, and from researching it seems the culprit is the multiple angels in the S.W films. I figure if I use DVD SHRINK or IFOEDIT to remove the unwanted angels, just keeping, say, Angle 1, then Doitfast4u, reauthorist and scenarist shouldn't have a problem getting the subs to sync up properly. At least that's what i'm hoping.![]()
If there is a program that can make an .ISO that way then I'm figuring I could use Daemon Tools to mount it and doitfast4u to create the project.
If what i'm asking can't be done, does anyone have any suggestions for the problem i'm having and how to still get rid of the unwanted angels but use the big three for the project?
Thanks much in advance for any info or help with this.
use imgtools (the classic)
guide, https://www.videohelp.com/forum/userguides/152875.php -
thanks for the information Baldrick. I had just come back to update this post and say I found what i was looking for when I went to the tools section and saw there were "7" tools under the .ISO tab.
CDMAGE and IMGTOOLS seemed like my best bet. I downloaded IMGTOOLS but didn't see any options to create an image, then quickly realized there was a classic version. Downloaded that and it seems to be doing exactly what I need. Thanks for the very prompt reply though! -
it's the angels again -- always mucking about ...
convert video_ts to iso?
By piscian18 in forum Authoring (DVD)Replies: 7Last Post: 26th Jun 2010, 16:17 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
Cannot create ISO file with this type VIDEO_TS menu, Why ?
By RWANDREWS in forum Authoring (DVD)Replies: 2Last Post: 30th Apr 2008, 13:44 -
iso to video_ts
By 69ers in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 18:56
