I'M capturing mostly from Satellite via DV.From time to time I'm getting the video in wrong field order (don't know why),i.e. top field first instead of bottom field first (PAL).Result is, the DVD is not viewable on a standalone (PC is working fine).Question:is there an easy way (i.e. without reencoding) to get the fields in the correct order?
Results 1 to 9 of 9
Originally Posted by FOO
You mean you are capturing to mpeg2 and even though you don't change the settings, the field order just changes sometimes?
Originally Posted by winifreid
Interesting thing, it didn't happen any more after replacing the SAT receiver.
But I fear, it could happen any time again. -
Are you converting to mpeg2? If so, change the field order in the program you are using to convert, rather than convert and then change the field order. I don't think it has anything to do with your Sat receiver. If I am not mistaken, field order is determined by the capture program.
Thanks for the responses.Restream does the job very fast and good.
And to answer the last post:Yes, I'm converting to mpeg-2.I'm using always the same capturing program (DVIO), but get from time to time different results regarding the field order.I only can see, that this is wrong after the conversion.Or is there a way to check this before?
I'm using avisynth to cut the movie.
field order wrong after AVStoDVD conversion
By 4evrplan in forum Authoring (DVD)Replies: 18Last Post: 26th Aug 2013, 15:59 -
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 07:58 -
MPEG2HD to DVD Conversion – Field Order
By miepel in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 22:14 -
Nero Vision 5 with ADVC-100 - wrong field order in NV5
By vcddude in forum Capturing and VCRReplies: 10Last Post: 28th Nov 2008, 17:22 -
> Ulead VS11 Broken MPEG 2 Field order <
By Dark Alpha in forum EditingReplies: 8Last Post: 24th Jun 2008, 08:29
