I have a non-copyrighted DVD that lacks a menu and has bad audio synch (noticeable delay).
I want to reauthor the DVD with a fancy menu and shift the audio ahead slightly. I do not want to convert/recompress any data.
My tools are Sony Vegas Video, Sony DVD Architect, TMPGEnc, and many of the other free utilities discussed on the board.
Using TMPGEnc mpeg tools "demultiplex" I demux each .VOB file to .m2v and .ac3 files. When I try to open these file types in Vegas video to merge and edit them, it tells me that the file types are not supported. How can a program render an ac3 stream but not be able to open one for editing? Will using different file extensions when demuxing in TMPGEnc do the trick (ie .mpg)?
Vegas cannot read .ac3 files, however some peopl ehave found it possible to drop a vob file onto the timeline and have vegas recognize it. If the audio is two channel .ac3, then you loose nothing by changing it to a stereo .wav, and using vegas to change it back again afterwards. Otherwise you will have to get the .ac3 back into it's original mono tracks (all 5 or 6, depending), and rebuild from there.
Read my blog here.
Thanks for the quick reply. No luck dropping .VOB into Vegas, in fact it won't even accept the .m2v files I've ripped from the DVD!
vegas will take vob files - or any program stream mpeg ..
try renaming the vobs to mpg (though you should not have to do this) .
you could also multiplex the m2v file to a program stream with tmpgenc with no audio
and as suggested - convert the ac3 files to wav files and go from there .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony Vegas+.ts=no video
By TheCryptiiC in forum EditingReplies: 9Last Post: 19th Jun 2010, 08:34 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Scaling down video in Sony Vegas 8
By jnaizer in forum EditingReplies: 2Last Post: 20th Feb 2009, 04:25 -
Help with Video filters in Sony Vegas 8.0b
By Fahad in forum Newbie / General discussionsReplies: 7Last Post: 11th May 2008, 12:35 -
Sony Vegas and video effects
By Greator1821 in forum Newbie / General discussionsReplies: 10Last Post: 19th Oct 2007, 12:46
