Results 1 to 17 of 17
  1. Despite a CD-R saying its capacity is 700MB, I've been burning VCDs with almost 800MB. Now, I'm moving into SVCD but they don't seem to be able to do the same thing. Only up to 700MB or I'm doing something wrong. Can someone please clear this up for me? Thanks.
    canada
    Svcd can be burned at 800 mb to a 70 minute cd but it has to be authored as svcd,nero can do this with the super video comiplation or you can author with vcdeasy selecting svcd and saving as bin/cue files which are burned as image files.
    Seaside, CA
    You stated: "Despite a CD-R saying its capacity is 700MB, I've been burning VCDs with almost 800MB." This is because the rated capacity on CDs is the mode-1 capacity, VCDs and SVCDs are burned in mode-2 format which allows up to approximately 800mb on a 700mb (mode-1) CD. If you have a 700mb mode-1 CD with the proper software and procedures you should be able to fit an SVCD compliant mpeg file that is near 800mb onto it. Maybe you should try another authoring program. I would suggest VCDEasy. It burns SVCDs also.
  4. Svcd is burnt as special format... mode2
    data Cdr are burnt as Mode1 which wastes space on error correction ! xvid/divx (film.avi), altho video files, are BURNT as data (re your other question)
    normal data Cdr 700-704mb
    normal svcd cdr 780mb
    99min data Cdr 870mb
    99 min svcd Cdr 980mb (check player for compatibility first!)
    The electronic components of the power part adopted a lot of Rubycons.
  5. Is it possible to burn data in mode-2?
    This plan is so bad, it must be one of ours.
  6. Yes!! but not all drives can read it... anyway u wouldn't want to....lack of error correction....and therefore little errors can cause serious problems to the data, i think?
    https://www.videohelp.com/tools?tool=451#comments <--- allows u to burn data in mode2, but i've never tried, never will and never will recommend it, but your choice.....
  7. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Exactly. A minor error can cause a program to freeze, while a VCD will only have a minor glitch in the video that you may not even notice....big difference.
  8. OK, when I run my two eps through vcdeasy, it says the CD size will be 782 MB but the finished product is actually 888 MB in size. I did get a warning about auto padding but don't know what that means. Anyone know why the vcdeasy files are over 100 MB larger that what they are supposed to be?
  9. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    try demuxing the video and audio in tmpgenc and then multiplex the streams back together as mpeg 2 SVCD. I think that will solve the autopadding issue in vcdeasy.
    Donadagohvi (Cherokee for "Until we meet again")
  10. Originally Posted by vdk_au
    I plan on just using it for storage, could i copy the files from the mode-2 cd without any problems?
  11. Thanks freebird. Demuxing and remuxing the vid and audio did the trick. How does it solve the autopadding thing anyway? I appreciate the assist. Thanks again.
  12. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    It has something to do with the way the file was encoded in the first place. If it was not encoded as a svcd it will require autopadding. Demuxing and remuxing is an easy fix though. I'm sorry I can't give you a more technical answer. I just know it works!
    Glad it helped you!
  13. Originally Posted by johns0
    I am not sure if I agree with this. I have been having a lot problem trying to figure out the output file size, so I can fit it into a CD-R. The CD-R says 700MB/80 min, I have this MPEG2 file at 785 MB, I tried using Nero and Video Easy to burn it as SVCD, and both indicated it's over the capacity of the CD-R by at least 10%. I have another MPEG2 file at about 699 MB, and it fitted right into a single CD-R when I burnt it with Nero for SVCD. Is there a way to "shrink" a MEPG file size by 10% with any of the tools such as TMPEGenc?
  14. Mod Neophyte redwudz's Avatar
    USA
    You can encode the video file to a smaller size with TMPGEnc by adjusting the bitrate. But if you save the larger file as a BIN/CUE file and burn it as an image file (Mode-2) with NERO or other programs you can easily go over 800MB. I have a large stack of SVCDs converted from DVDs with DVD2SVCD that average 830MB and they play just fine.
  15. Can I trouble you for a step by step on how and which program/tool to do that?
    Unfortunately, I have yet been able to convert a DVD with DVD2SVCD. There is always some file missing or some file that cannot opened.
  16. namsilat,
    I use vcdeasy to make an image of the mpegs with chapters and then use the use nero's SVCD option. VCDEasy does add 10MB to the image which would just put you over the limit. I would demux the audio and video, reencode the audio to a lower bitrate and mux the two together before running it through VCDEasy. Here is a guide that shows how to use VCDEasy. Just skip down halfway through the guide:
    https://www.videohelp.com/sefy/?id=divx2vcd.html
    Just be sure you change the template to SVCD 1.0 where you see "VideoCD Type".
