I simply can't address general complaints. Post the *.INF file from MDGx.
--edit--
OK, i think i've found the *.INF file your talking about.
http://www.msfn.org/board/?showtopic=38261
Then laterOriginally Posted by miko
-------------------------------------------------------Originally Posted by MDGx
This *.INF looks suspiciously familiar.![]()
It looks like someone has added settings for Windows Media Player. It would be a good idea to use one or the other *.INF but you would certainly run into problems if you installed this one first and then installed mine. As soon as you uninstalled mine the settings for Windows Media Player would be orphaned.
By themselves there is really nothing wrong with either one. They both answer a different question.
Results 31 to 37 of 37
Well your INF was tried before anything else was tried, so I'm not sure how the MDGx INI would have influenced the uninstall procedure of yours. Also, I'm not asking you to address my complaint, I signed up here just to let you know it happened. I *wish* I could help you address whatever happened, for you sake. I'm done with messing with this INF. I made a batch file for myself that just does self-register method, using FhG 3.4.0 version.
Thanks for the efforts though, I'm sure it works fine for 99% of people. -
Refresh your page. I just edited the last post.
If this is the *.INF that your talking about i see nothing that would uninstall your codecs as soon as you installed the INF.
My Diagnosis: User Error
Since the MDGx *.INF and the one i posted are almost 'One-In-The-Same', they should affect your system in almost the same way. If you install both, and then uninstall one of them, the codec itself will be removed from your PC but remaining entry in "Add/Remove" will be left behind.
In it's present state this *INF just isn't capable of uninstalling any video codec.
--edit--
I just noticed that the "modified" (miko) version of this *.INF has the 'NT' stuff removed. If someone installs this on Win2k or WinXP they might not get the registry settings in just right.
There is a difference that probably won't work right on a Win2k-XP system in the MDGx *.INF.
Originally Posted by mikoOriginally Posted by mikoOriginally Posted by mikoOriginally Posted by mikoOriginally Posted by miko
But according to Microsoft, the XP version should have quotation marks (in red).
Description of the MP3 Encoding Plug-In for Windows Media Player for Windows XP
http://support.microsoft.com/kb/306494
HKEY_LOCAL_MACHINE\Software\Microsoft\MediaPlayer\ Settings\MP3Encoding","LowRate",0x00010001,56000
HKEY_LOCAL_MACHINE\Software\Microsoft\MediaPlayer\ Settings\MP3Encoding","LowRate",0x00010001,24000
HKEY_LOCAL_MACHINE\Software\Microsoft\MediaPlayer\ MP3Encoding","PreferredCodecName ","YourPreferredCodecName"
HKEY_LOCAL_MACHINE\Software\Microsoft\MediaPlayer\ Settings\MP3Encoding","PreferredCodecPath","C:\\WINDOWS\\system32\\YourPreferredCodec.acm "Whats clear here is that miko never intended this file as a fix for Windows XP. It's clearly labeled "WIN98SE".
--edit--
But that isn't the way it's listed at MDGx's site;
http://www.mdgx.com/wmp.htm#L3C
well I'm glad I at least brought this to your attention. the miko version has propigated itself around the net very well, and the several most popular places (according to pagerank) are all either not listing the compatibility, or actually saying it's for 2K/XP. >_<
Well at least I'm a lot more familiar with how INF installs work now.I can thank miko and MDGx for that. Actually, I thought you were miko at first, but after comparing there are some big differences in the INF... not to mention - where's his thanks to you?? He didn't even mention that he didn't make (or more like f* up) the INF he posted all over the place. Oh well, it's not my concern.
thanks for the info about the profiles too. i did need to go in and set those up again on my system after MDGx's INF deleting them after his uninstall >_< so that is a good help. -
I didn't do this to be famous.........and i borrowed from other sources too. That's how ya learn how things work.
The version from MDGx (http://www.mdgx.com/files/L3C.EXE) is trimmed down further, and doesnt resemble mine at all.
[Version]
Signature=$CHICAGO$
[DefaultInstall]
CopyFiles=CF,CI,CT,CX
Updateinis=U1
AddReg=M1
[UNX]
AddReg=MX
DelReg=RD
DelFiles=CF,CT,CX
Cleanup=1
[CF]
L3CODECP.ACM
[CI]
L3CODECP.INF
[CT]
L3CODECP.TXT
[CX]
L3CODECP.ACM
[U1]
SYSTEM.INI,drivers32,,"msacm.L3acm=L3CODECP.ACM"
SYSTEM.INI,drivers32,,"msacm.L3codec=L3CODECP.ACM"
[M1]
HKLM,Software\Microsoft\Windows\CurrentVersion\Run OnceEx\L,3,,"%11%\REGSVR32.EXE /S %11%\L3CODECP.ACM"
HKLM,Software\Microsoft\Windows\CurrentVersion\Sha redDLLs,"%11%\L3CODECP.ACM",0x00010001,1
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\drivers.desc",L3CODECP.ACM,,"Fra unhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Drivers32",msacm.L3acm,,L3CODECP .ACM
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\Drivers32",msacm.L3codec,,L3CODE CP.ACM
HKLM,Software\Microsoft\Windows\CurrentVersion\dri vers.desc,L3CODECP.ACM,,"Fraunhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,Software\Microsoft\Windows\CurrentVersion\Dri vers32,msacm.L3acm,,L3CODECP.ACM
HKLM,Software\Microsoft\Windows\CurrentVersion\Dri vers32,msacm.L3codec,,L3CODECP.ACM
;MP3 Codec Encoding Settings:
;LOW RATE = 64 kBps @ 22.050 Hz:
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,LowRate,0x10001,00,fa,00,00
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,LowRateSample,0x10001,22,56,00,00
;MEDIUM RATE = 128 kBps @ 44.100 Hz:
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,MediumRate,0x10001,00,f4,01,00
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,MediumRateSample,0x10001,44,ac,00,00
;MEDIUM HIGH RATE = 160 kBps @ 44.100 Hz:
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,MediumHighRate,0x10001,00,71,02,00
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,MediumHighRateSample,0x10001,44,ac,00,00
;HIGH RATE = 192 kBps @ 44.100 Hz:
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,HighRate,0x10001,00,ee,02,00
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,HighRateSample,0x10001,44,ac,00,00
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,PreferredCodecName,,"Fraunhofer MP3 (professional)"
HKLM,Software\Microsoft\MediaPlayer\Settings\MP3En coding,PreferredCodecPath,,"%11%\L3CODECP.ACM"
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3acm,Description,,"Fraunhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3acm,Driver,,L3CODECP.ACM
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3acm,FriendlyName,,"Fraunhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3codec,Description,,"Fraunhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3codec,Driver,,L3CODECP.ACM
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\acm\msacm.L3codec,FriendlyName,,"Fraunhofer IIS MPEG Layer-3 Codec (professional)"
HKLM,Software\Microsoft\Windows\CurrentVersion\Uni nstall\MP3WMP9,DisplayName,," L3C: Remove WMP10 XP MP3 Codec"
HKLM,Software\Microsoft\Windows\CurrentVersion\Uni nstall\MP3WMP9,UninstallString,,"RUNDLL32.EXE ADVPACK.DLL,LaunchINFSection %17%\L3CODECP.INF,UNX"
[MX]
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once,Lx,,"%11%\REGSVR32.EXE /S /U %11%\L3CODECP.ACM"
[RD]
[DestinationDirs]
CF=11
CI=17
CT=10
CX=11,DLLCACHE
[SourceDisksNames]
1=,,0
Originally Posted by MDGxOriginally Posted by miko -
yeah, well... the first version i tried was actually the miko version, not yours. like i said, i thought you were miko at first (due to his being copied from yours without credit) so sorry about the confusion.
how to setup automkv to use lame mp3 encoder instead of fraunhofer
By deejay.2001 in forum Video ConversionReplies: 0Last Post: 1st Aug 2009, 06:42 -
WMP10 and WMP11 commercial DVD playback Solved
By gll99 in forum Software PlayingReplies: 4Last Post: 26th Jan 2009, 07:22 -
HTC Verizon XV6800 WM6 WMP10
By TEXASGIANT in forum Portable VideoReplies: 2Last Post: 20th Jul 2008, 18:37 -
WMP10 - why this distorted MPG?
By terrypin in forum Newbie / General discussionsReplies: 16Last Post: 14th Nov 2007, 07:16 -
Advice on getting .mp4 to play in WMP10
By Stormy24 in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2007, 11:47
