Hello everyone. After a successful install of Star Wars Battlefront, I'm unable to start the game; I get this error, "No TnL detected on your display adapter." What does this mean and how do I solve this problem. Does this have anything to do with a 3D feature?
Results 1 to 9 of 9
it probably does. what vid card u runnin?
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
try and update your mobo then your vid card. its a hardware issure i guessHardwareTnL=FALSE - This tells EQ to not use the Hardware Transform and Lighting features of your video card (if it has them). We do attempt to detect this and most people will not need this line, however some drivers report false information or some setups may not work well with hardware TnL, so this option is there for those situations. You can also set this to TRUE to force EQ to try and use HardwareTnL, this may help some people if there setup is not detected correctly.PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
I have a DELL E771a on ATI Technoligies Inc. RAGE 128 PRO II ULTRA GL AGP my chip type: Rage 128 Pro II, (AGP 4X/PCI)
DAC Type: Internal DAC (350mghz) Is this not good? -
That card is from 1998. Even a Geforce 2 MX is better than that. I'd recommend the GeForce FX 5200 PCI. It has 128 Mb of DDR RAM on it, and you can get it for around $80 online.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
no, just uninstall old vid card driver. shut down puter put in new card and install new drivers. and baaam, good to go. i would try updating your mobo drivers first though before going out and spending $$$
As Forum Troll says, the FX5200 is a good card, and is probably the best you can do for the price. However, in comparison to higher cards, the FX5200 does not offer much bang for your buck and so you may want to look at splashing out on a 5900XT. It's a nice, fast card with more memory bandwidth (this can be more important than amount of memory in some cases). My brother owns an FX5900XT and it is a very good performer.
If you're happy with a cheap, no-frills card that will let you play your games then go for the FX5200. If you want an upgrade that should last a bit longer and give you a more involving experience, then perhaps spending a bit more might give you more enjoyment.
Cobra -
Originally Posted by Cobra
Yeah, I bought a 5200 and I really regret it. Get yourself a nice Radeon 9600/9800 or GFFX 5900/5950.
Pixel format was not specified and cannot be detected
By videoBandit in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 16:45 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
Test Pattern Generator software techniques and Display Adapter S-video Out
By cybertheque in forum Capturing and VCRReplies: 13Last Post: 27th Sep 2008, 01:35 -
VBR Audio detected
By timmer545 in forum AudioReplies: 16Last Post: 31st Mar 2008, 11:17 -
Camera Not Detected
By Poke598 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 25th Jun 2007, 12:39
