I'm using NeroVision Express 2, and currently trying to burn Teen Titans. I have converted the .AVI file to MPEG2 and have viewed the actual MPEG2. When showing on my computer, the MPEG2 files runs fine/no audio problems but as soon as it is transitioned to DVD and is complete the AUDIO does not match up with the drawings..
I've burned it three times now, set HIGH priorty all times and closed out all background processes yet the voices/sounds arent in sync.. The AVI/MPEG file itself plays great though..
Anyone have any ideas what I'm doing wrong, or what I should be doing to fix this problem?
Did you use Nreovision to encode the avi to MPEG-2? That could be the problem. Try encoding the avi in TMPGENC and then author the DVD, see if taht fixes the sync problem.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
