Ok, I have winrar figured out up to a point. I've started downloading a file that has more than 100 parts, so the extensions changed to .s files. For some reason, these are not showing up as winrar files. Anybody know what's up? I'd like to know before I finish the download, get ahead of the problem if possible.
Thanks!
Liz
Winrar registers all filetype with the extension .r?? as WinRAR type - hence they appear with the WinRAR icon.
As every file type (.rar, .r00, .r01, .r02...) is registered separately, which means Winrar already registered over 100 file types with itself, some kind soul at RARsoft spared us and didn't register all the .s??, .t??, .u?? etc. with it.
Even though Windows will regard them as 'unknown type, WinRAR will recognize and deal with them. As a matter of fact, you should usually care only about the .RAR file - WinRAR will continue with the next ones as it may need, going to the .s?? and .t?? when needed without asking unecessary questions (wish I could say that about myself).
-- Piggie
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 17:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
