  1. I have a .bin file and I'm trying to extract it to .mpeg or .mpg, as long as I can watch it. But the problem is that the file is MPEG2 and when I "Extract but FILTER only M2F2 Mpeg frames" I can't get the video to play. When it asks what filename I want to put it under, I type in "AVSEQ01.mpeg". Then it goes through the extraction, and when I play the video, it doesnt work. But when I extract MPEGAV, it works fine.
    What am I doing wrong for the MPEG2 extraction?
    In the world I see - you are stalking elk through the damp canyon forests around the ruins of Rockefeller Center.
  2. bump?
  3. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    What are you trying to watch the mpg with? If you don't have a mpeg2codec installed on your system you probably won't be able to watch it. Try downloading mediaplayer classic as it has a built in mpeg2 codec.
    Good luck!
    Donadagohvi (Cherokee for "Until we meet again")
  4. Banned
    Jan 2004
    Going in Circles
    Or you could try powerDVD.
  5. Originally Posted by gitreel
    I was trying to watch it with the most current edition of WMP, does that not support MPEG2?
  6. Mod Neophyte redwudz's Avatar
    USA
    WMP supports MPEG-2 but Windows doesn't come with it. You have to install a MPEG-2 codec to view them. PowerDVD installs it or you can find one in the 'Tools' section to the left under 'Codecs'.
