Hi everyone. One simple question:
I want to buy a new DVD player. I live in Brazil, and I'm inclined on two players:
1 - Philips DVP-530
2 - SONY DVP-NS575P
They both play DVD, DVD+R/RW, DVD-R/RW, VCD and SVCD and are progressive scan
Now the question: does it make any difference to buy a progressive scan dvd if you television set DOES NOT HAVE progressive scan?
I have a 28" Widescreen TV (Philips 28PW6521/78R), and it does not say anything about progressive scan.
Anyone?
It only works on digital TV's. I'm not sure if yours is digital but if is a regular analong TV, progresive scan won't work.
Imagination is More Important Than Knowledge -
The progressive scan video output will only work with TV's which are capable of displaying a progressive image (480P for DVD). In the USA almost every widescreen TV is capable of progressive scan. I don't know about Brazil.
Hoewer, every progressive scan DVD player can be set to output non-progressive (interlaced) video. So they will all work with your TV.
I would recommend the Sony DVD player. Also, to get the best picture, you should use component video cables to connect the DVD player to your TV.
-T -
The Philips might be region free by entering a few numbers on the remote. Then you can watch movies from all over the world.
Thanks for all the replies guys! I do use component cables with my TV, and the difference is astounding if compared to regular RCA cables... I also use digital coaxial audio - is the optical better?
Finally, I am more inclined to buy the Philips one, exactly for the reason appoited by GabeB - I already have the necessary region codes... and I haven't found them for the SONY player.
Thanks again -
For the audio, I can't tell the difference between the two. My audio equipment is under a 1000 dollars total so maybe on a high end system there is a difference. Both cables output the same exact information.
Sony players are generally not region free.
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 17:22 -
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 07:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
Do laptop dvd drives play in progressive scan?
By ieh4f in forum Newbie / General discussionsReplies: 8Last Post: 29th May 2008, 20:36 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 20:58
