  1. I am having a problem with the sudio and video syncing up in DVD lab. When I convert my avi to Mpeg using TMPGEnc the audio is fine and is sync'd properly.
    But when I put the mpeg into DVD lab and compile my DVD the audio and video don't sync up anymore? Does anyone know how to fix this problem?
    Don't look at me in that tone of voice.
  2. get a prog called "ifoedit" and use that.
    seperate the mpeg into an .m2v file and an.mp2 file,in mpeg tools in tmpgenc.then author new dvd in ifoedit.
    after thats done,just stick the vobs into dvd lab-it will ask if you want to join them,say yes and continue as normal,adding the joined vob as the video and audio,that way it wont be out of sync,as it wont touch them,just joins them together.
