  1. well My Problem is that am learning how to use this 'Endcoding' thing and i have had alot of mess up becuase i always had a problem with my anime vcds freezing up on fames and they conutune to talk. Well my problem is i thought i could fix my problem with my animes buy turning them into svcds but that fixed the freezing frames but now a new problem.
    the music messed so over time i prefected it alone story short i fixed the problem. now what the my prob is now i cant reencode svcds to mpeg or regular vcds i use TMPGEnc 3.0 Xpress PLEASE HELP SOMEONE!!!! it is really being a pain!!!!!!
    manga and videogames are not a pass time IT IS A WAY OF LIFE!!!!
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    download dvd2svcd to use together with tmpgenc. It will handle all the settings for you. Very easy to use. With it you can create vcd or svcd.
    Good luck!
    Donadagohvi (Cherokee for "Until we meet again")
  3. THANKS MAN I WILL TRY IT!!!!
  4. Man This Thing is sooooo confusiing can yo give me a little help!!!!!!!
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    select the source , select the file type you are going to make and press the start button ..
    if using tmpgenc as your encoder - make sure it is listed and selected as the encoder ..
  6. i do not see a go button can you please give me a mini walkthrougt please thanks!!!
  7. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
