  1. Guest
    Guest
    I went to defrag my main partition on my hard drive to find it nearly full! It should be nowhere near the 120gb limit. Last month I defragged and it was like 1/5-1/4 full.I back up isos to a different partition. I am looking for freeware that will help me identify where all of this space is being used. I used to have a program that would tell you the folder size in the root tree. I cant remember what it was called.That would be a start,unless anyone knows of a better program.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Porn.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Yu can use windows search to specify files of a certain size.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Pardon me if I've missed something, but can't you just right-click on any folder and go to properties to see how big each folder is ?
    If in doubt, Google it.
  5. Hey Doc
    Give "Mousesoft Directory Size" a look
    http://www.mousesoft.co.uk/mds.htm
    Freeware
