hi there i have kind of a problem im trying to get tmpgenc to read vob files but no luck
Tmpg reads the video file but no audio file
i did a search and various said about AC3 ACM i did download this recompressor and installed it in my winxp pro sp1 but again nothing
tmpg cannot openthe ac3 files
Can you propose anything?
Results 1 to 11 of 11
The usual way: Extract audio and decode to wav with VirtualDub. Use your original source as video source only, the extracted wav as audio source in TMPGEnc.
/Mats -
No can do. It's not supposed nor intended to. Has never been. It's a video encoder. And very good at that. It's not that good as audio de/encoder.
/Mats -
I don't know why it's not working, but the last post is incorrect. It can do. If you have the AC3 plug-in then it's supposed to because that the only purpose of the AC3 plug-in.
I use the AC3 plug-in and it's as good as any other software I've used for AC3.
Since you have the AC3 plug-in, have you emailed the company to see if they can help? -
The DVD Author AC3 plug-in only supports 2ch AC3 it doesn't accept 5.1ch.If you want to make menus with 5.1ch AC3 I suggest DVDLab then transcode with DVDShrink.
This is from pegasys website:"*But Dolby Digital (AC-3) with 5.1 channels or other multi-channel sources cannot be encoded".Also you need to update the license periodically: www.pegasys-inc.com/en/info_lic_val.html -
guys im not talking about pegasus plug in but for AC-3 ACM Decompressor by fccHandler
http://fcchandler.home.comcast.net/AC3ACM/ -
TMPGEnc can read AC3 audio with the AC-3 ACM Decompressor installed. Did you try raising the priority of the Directshow filter in TMPGEncs environmental settings?
yes i did raise the priority of the Directshow filter but no luck
i really do not understand why its not working for me
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 07:03 -
AC3 Files with TMPGenc
By PHNeedsHelp in forum AudioReplies: 3Last Post: 4th Nov 2009, 12:37 -
TMPGEnc plus & ac3
By natty in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 09:01 -
Can TMPGEnc open AC3 audio?
By TheEvilHammer in forum Video ConversionReplies: 14Last Post: 17th Mar 2008, 15:32 -
TMPGenc Plus and VOB with AC3
By arturjose in forum Video ConversionReplies: 2Last Post: 19th Jul 2007, 12:02
