Hi all, I was just wondering, is there a software, and if there is which is the best to edit movies and audio.... When I mean edit, I would like (if it exists) a program that I can open the mpeg/vob etc file, and cut, re-arange, fix the audio, etc, etc. Just like I can in Sound Forge (with music).... TMPGEnc only allows you to cut parts of a movie, but what if I want to shift frames around, or cut from one video and add to another.... things like that....
Is there such a software, that wworks like sound forge, and does video and audio????
Thanx in advance for any info....
LOL
Eminence
You need a good editor to get full control. Three choices really, as mentioned above Vegas, Premier or Medis Studio Pro. All have roughly the same features. I use MSP, you can add as many diiferent video tracks as you want, and up to 6 audio tracks. When I say that there's 6 simultaneous tracks, as many pieces that will fit in the timeline can be added. You can split the audio from the video, adjust the length od the audio..... really no limits.
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 13:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 07:46 -
Sound Forge --> Speech Over Background Music
By Omnipulator in forum AudioReplies: 0Last Post: 20th May 2009, 23:00 -
Recording music,editing,adding sound effects ect...
By f-zer0 in forum Off topicReplies: 6Last Post: 20th May 2008, 07:44 -
Vegas Movie Studio 8 Platinum Music/Sound effects
By Nuke Shower in forum AudioReplies: 3Last Post: 21st Apr 2008, 00:58
