  1. I have a bin and cue. I burned the image to CD using Nero. I put it in my TV DVD player and it doesn't bring up the menu's properly (it brings up some jpegs).
    If I put the disc in my computer, it starts and goes right to the menus (these are homemade menus).
    So, I look at the disc and there are mpgs on it and I figure I can rip them off and then reburn without the menu stuff (or something like that).
    Well, when I try to get them off I have problems. I tried ISO Buster on the original bin;cue and all I got was 0 byte files. I tried to open them in Dr. Divx and no luck. I even tried DVD Santa.
    I can't seem to open them in any program. I'm kind of lost now. I don't know what to do. I should probably know but I just don't. I could use any help you can offer.
    Edit: Forgot to mention they are AVI files
  2. Member monzie's Avatar
    Nov 2003
    The Village
    Point Isobuster at the .bin file, right click on the tree view and use the <Extract but filter only M2F2 Mpg frames> to extract the mpeg file.
  3. All I get when I do that is 0 byte files. Weird.
  4. I tried avi2vcd and it says I don't have the right codec.
    But it plays just fine in the computer drive.
  5. Member venomva's Avatar
    Feb 2003
    Long Beach, CA
    what you might want to try is hitting Title or Menu on your remote. I made a menu and when I put the dvd in my player it just started playing the movie. After hitting the title (menu) button on my remote then it showed the menu I made.
  6. I tried hitting title and menu. I tried all of the buttons.
    I think the problem is that there are jpgs on the CD root so my player is playing the jpgs (that's what I see). I could get around this by removing the jpgs but I can't get the darn video off the cd.
