My PC specs are as follows:
Windows ME
Celeron 700mhz
192M PC100 RAM
I know this is an old computer. I've ripped and encoded and my speed on encoding is 880 kb/s. Is this normal for the specs of my PC. I'm using DVD Decrypter.
Also, will adding memory help with the speed, or is it just the fact that I have an old and slow processor. I'm thinking of adding a 256mb stick and taking out the 64mb stick to get 392mb RAM. How much will it help?
And I do realize that sooner or later, I'm going to have get a new PC.
Sorry to say: not much. You have a friend with memory to spare or lend, try it. Celeron 700 would be about PII 500 speed. Stick with it as long as you have to and then get yourself something in the range of 2.5-3 GHz with 512 memory.
The Extra RAM will make some difference however that old Celeron 700 I suspect will be the main bottleneck , a faster more modern CPU will encode that video so much faster .
Agreed. You need more ponies under that hood.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
RAM usage drops drastically after encoding
By Moontrash in forum ComputerReplies: 2Last Post: 2nd Dec 2010, 22:16 -
hauppauage hd pvr, what encoding rate?
By krohm in forum Capturing and VCRReplies: 6Last Post: 15th May 2010, 10:15 -
MainConcept H.264 frame rate issues encoding Final Cut output
By soandso in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 13:46 -
Frame rate question
By janlafata in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2009, 19:37 -
RAM question
By mvp in forum ComputerReplies: 3Last Post: 7th Jun 2008, 16:03
