Hi,
My inlaws went to China and hired someone to video tape them while they were on tour with family. They had a VCD made of the tape that worked just fine in China. But when they got back and popped into their DVD, it came up in black and white. All the color was lost. It does work OK on my computer though.
I know almost nothing about VCD/DVD stuff, but I suspect it has something to do with the region code. I looked through the FAQs with very little success.
Is there a (hopefully free and easy) way to fix this?
Any pointers will be gratefully accepted.
Thanks,
Dave
If you still have the tape you should do it again in NTSC instead of PAL.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
yeah,its been made with the PAL60hz settings.
just reconvert it on the pc to ntsc,it should be fine. -
I have been going to China at least once a year for the last 3 years. I never have that problem.
It's time to kick some butts, and presto ( if you know what I mean ) -
Thanks for the quick replies.
Unfortunately, I never had the tape. This was a (semi-)professional outfit that made the VCD back in China.
Any pointers on how I might go about converting it to NTSC? I'm fairly adept at figuring out new SW, but there seems to be so much to choose from that I'm not sure quite where to start.
I'm not a video enthusiast, I'm just trying to score some points with my mother-in-law. :-)
Thanks again,
Dave -
Thanks deckard8!!
That's exactly what I needed to get me started...
I'll post when I've got it done...
Thanks,
Dave
Can DVD Disk Made Here be Replayed in China?
By wangy26 in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2009, 19:40 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 06:57 -
Media Made in India, Thailand, China or Taiwan.
By DroWni in forum MediaReplies: 1Last Post: 16th Sep 2008, 14:45 -
Where can I buy (in USA) Verbatim DVD+R DL made in Singapore?
By JohnnyBob in forum MediaReplies: 12Last Post: 10th Dec 2007, 12:34
