post some samples from it
Results 31 to 60 of 77
cut out some mpeg samples and send them to me or upload the here -- this forum (now) supports files
doesn't need t be a large sample - just a dark scene and a light scene ..
even a couple frame grabs from the dvd would be something to look at and i can offer some opinion maybe"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ok, so I'm not sure how to get a sample,, it's already mpg format, I can open the mpg in vegas,, can i re-render it to mpg? will that screw things up?
Good point, vhelp. I've got my overlay set with a custom "NTSC" preset I made, so the tv set and the computer preview are identical (pretty much).
pretty identical???? Since you seem to have everything wired over there, how do you do it? I thought the basic conclusion was screw it you can't do anything about it since TVs and computer monitors are different,,, what's your fix?
only a 2mb limit??
i was looking at the raw avi capture on my television and on another computer monitor,,, it was just too dang dark on the monitor =( -
what is clip.mpg supposed to be as it doesnt have a header and doesnt play
that's the .mpg clip you requested,,, I just clicked on it and it says not found,,, is that because it's over 2mb? it's 2.5mb
http://tsl_v4.swf/ is the link you have there -- which doesn't work ... :
plus compressing mpeg to shockwave - i'm not sure what that does to color compression , but i'm sure it's not good"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
oh, well I don't know,, there's only a 2mb limit, and the mpg2 will be bigger than that
get a smaller sample or frame captures
ok I'll try that...how come it's not uploading properly anyways?
maybe it did and you didnt link to it properly
i "found" your swf file
its here
https://www.videohelp.com/forum/images/guides/p1052651/tsl_v4.swf"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ok trying again with a smaller mpg clip
tsl_v4_clip.mpg
Play it on your computer monitor, and play it on your tv and see the difference - This clip hasn't been altered, just rendered from the raw avi capture.. -
grrrrrrr, why is it doing that?
I'm following the instructions aren't i?
filename.zip
so I put
and put the file in the lil upload box
why is it not working????????? -
maybe - not sure
ill try one
test clip
karate_champ.mov"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yea -- appears so
kewl, well check it out and see what your verdict is,,, I used a television as my monitor when I shot the video the other night, looks good on my other TV, but the dang computer monitor, it's darrrk
you want it to look more like this i guess
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
Is this true? DVD can't be played on older computers?
By jjachin in forum Authoring (DVD)Replies: 23Last Post: 12th Nov 2009, 10:49 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 21:51 -
Your computers. Show them to me.
By Faustus in forum Off topicReplies: 29Last Post: 20th Jul 2008, 11:43 -
computers very slow
By toolady in forum ComputerReplies: 18Last Post: 24th Jun 2008, 08:44
