Not quite sure how to ask this question, but here goes:
I'm making music instruction DVDs once again. So I shoot the video, drop it into the computer, open it up on a timeline in Vegas. And I have it being shown on my external monitor (a properly calibrated TV)
Now I'm looking at the TV, everything looks great, color, brightness, everything....and I"m looking at the preview window in Vegas on my COMPUTER monitor, and it's soooooo much darker.
If I make the necessary adjustments to make it look good on a computer monitor, then it gets waayy to bright and washed out on the Television screen....
What is the fix here? Customers buy DVDs for playback on both televisions and on their computers.
Closed Thread
You didn't specify what monitor you had, I would suggest that you need to calibrate your monitor. I have a similar issue with my camcorder's display being very bright and darker on my monitor, however the DVD's I've produced look fine when played back on DVD players (with no brightness adjustment).
There are quite alot of programs that will assist you in calibrating your monitor and quick search will help you, I myself use Adobe gamma utility which is included with Photoshop. Even just using the advanced setting in the Display properties might help to set the brightness of your monitor. Most monitors also have OSD (on screen display) setting which will also allow you to change the appearance of your screen. As with all things reading your manual will help you.
Calibrate monitor :
http://www.praxisoft.com/pages/products.wiziwyg.html
NTSC analog television handles black differently to digital (MPEG2)
http://www.signvideo.com/dv-black-level-dvd-7.5-ire-0-ntsc-part-2.htm
You may need to do seperate encodes (disk authoring) .
One for TV and the other for computer based. Or ask your customers what applicaton they use for playback on the computer because some play back darker than others. eg: WMP seems to play back darker than most.
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
best HD editor for producing DVD
By mtrax in forum EditingReplies: 14Last Post: 12th Aug 2009, 03:59 -
Video editing computer's drives
By ProducerHarley in forum EditingReplies: 6Last Post: 17th May 2009, 12:12 -
Producing flashvideo in executable format
By SearchQuality in forum Video Streaming DownloadingReplies: 0Last Post: 1st Dec 2008, 12:51 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21
