ok
When ever I try and split an AVI file, or try to join 2 files....
It goes for about 40 seconds and then I get the following error
"Unable to to <filename>. Parameter is Incorrect"
This happens EVERY time!
What is going on?
I followed the instruction to the T from the afonic video guide listed here on this site
The files were recently transfered to my computer from a miniDV camcorder via Firewire cable-
I am using "WinDV" to transfer the footage FROM the camcorder TO the computer
Any ideas?
I take it that the files you are trying to use are DV AVIS - correct? If that's the case, you will need to install a DV codec in order for Virtualdub to read the files. There is a good freeware one available - the Panasonic DV codec. This will enable you to read in DV files, and also output the results (i.e. encode) as DV as well.
The new experimental version of Virtualdub (1.6.0) has a built in DV decoder, but no encoder."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
