  1. Hi I have 2 video files in *.bin format i tried to burn them to disc using nero 6, it wont accept the files when I select them, I tried to burn them as an image and it will accept the *. cue files as video files to burn, but i wanted to get them 1 one disk not 2, it will only accept one *.cue file at a time so I presume it will only burn one of the files only to one disk therefore my video will be made up of 2 disks, is there a way round this does tmpeng or virtualdub for example join *.bin files togheter, or what options have I, or can *.bin files be converted to avi or mpeg or wmv etc, and then joined as one??, many thanks in advance,
    dosie.
  2. A .bin file is a disk image. A .cue file is a small text file that tells your burning program how to burn the .bin file.
    If you want to join the two movies together, the 1st step is to extract the movies from .bin files. Do this using Isobuster. Your next stemp depends on what you find when you extract the movies.
