hi, i've got a pioneer 107d, and was thinking about adding another to my system, any of you done, or know how to do this, and if so, is it easy to write to 2 dvd-r's at the same time, without making lots of coasters, tia
Results 1 to 10 of 10
Nero supports multiple burners but:
1. You are burning the same data stream i.e.you have two copies of the same disc.
2. The burning rate is capped at the slowest burning rate of your multiple burners i.e. you can't burn faster than the slowest burner. -
WHen I want to burn the same image twice I use nero. But to burn 2 different discs at once I just have 2 instances of dvd decrypter running.
I guess that will work if you have each instance of DVD Decrypter using a different burner.Originally Posted by Treebeard
as long as your puter doesnt still say packard bell you should be cool.
so how do i set it up, 1 have 2 harddrives on the 1st ide channel, do i use the 2nd ide, and set one writer to master, the other to slave..? and then use nero...?
yes use the 2nd IDE and set one to master and other to slave. then use nero.so how do i set it up, 1 have 2 harddrives on the 1st ide channel, do i use the 2nd ide, and set one writer to master, the other to slave..? and then use nero...?
I use NERO or ALCOHOL 120 %
Both can burn to multiple burners. I have 5 indentical Sony Dru 530 ul external firewire drives daisy chained together. I use that setup to burn up to 5 disks at a time from a single master file. Be it an image ( In Alcohol ) or both Images or VIDEO TS files ( in Nero ). I produce instructional hobby related videos and shoot events proffessionally.
I can fill a 20 dvd order, burn and print in like 50 minutes total usingf 8x media. Occassionally, about 1 out of 100 burn cycles I get a failure where one drive for whatever reason will fall behind and that burn fails. The rest continue and end perfectlyNo DVD can withstand the power of DVDShrink along with AnyDVD!
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 16:18
