  1. First burn attempt failed.
    When I use DVD shrink and open the files on my hard drive, DVD shrink wants to make another copy of everything.
    What application can I use to just burn them to DVD ?
  2. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    Burn the VIDEO_TS and AUDIO_TS folders DVDShrink created using the burning program that came with your writer. Burn them as data files. Make sure to copy the entire folders, not the individual files within them.
  3. Originally Posted by HarryMangurian
    DVDShrink can be configured to burn with Nero (version 5.5.10.20 or later).
    Mar 2004
    Southern California
    To expand on the excellent replys above, DVDShrink cannot burn dvd's. You will need a seperate burning app. see tools section (thttps://www.videohelp.com/tools?s=16#16) there are dozens, costing 40 to 80 bucks. Use the prog that came with your burner as louv68 stated, or use one of above, or for free burn with DVDDecryptor. You will have to convert your shrink output to iso to burn with decryptor. you can also configure shrink to burn automatically after rendering using nero as jyn999 stated or decryptor. search guides for dvd shrink settings. good luck.
  5. You could use this free burner ( DeepBurner ). I installed it on my sisters computer and it seemed to work well the few burns I did with it plus can't beat the price.
    https://www.videohelp.com/tools?tool=491#comments
