Does ProCoder support frameserving from VirtualDub?
I tried it last night and got a unsupported file format error.
Thanks!
LS
yes it does -- use vfapi.exe to convert the vdr to a avi
or did you try this first ?
https://www.videohelp.com/forum/viewtopic.php?p=1051312#1051312"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
works fine here - sorry
vfapi does not work with long file names or directories though - just to let you know .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Maybe that is it. I always use long filenames. I'll give it a shot.Originally Posted by BJ_M
LS
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
chapters with procoder 3
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2007, 11:20 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25 -
framserve PGC
By kurbads in forum Newbie / General discussionsReplies: 10Last Post: 3rd Jul 2007, 08:03
