Having a basic understand of a pc using Raid configuration I was wondering if it is beneficial to video editing. I have always understood that a dedicated hard drive was needed to capture video footage.
I believe you can capture to a RAID array, but I am unsure as to the benefit of doing so. Are you really going to need to write more than 25-30MB/sec to capture video?
I am no expert on video capture though... -
you only need raid 0 if you are capturing uncompressed video or hd ...
some high end cards require this (and scsi only) //
for dv or capture to mpeg and that sort of thing -- you dont need raid 0 , but a 7200 or higher drive is nice thing .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Agreed, the two drives singly will work more to your advantage when you're encoding. Read from one and write to the other rather than read/write to the same drive, even a RAID volume. RAID 0 increased data bandwidth to not quite double but it doesn't increase any seek/access times.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
RAID question
By mysts in forum ComputerReplies: 5Last Post: 6th Jul 2009, 15:31 -
Raid 5 to Raid 1
By mysts in forum ComputerReplies: 4Last Post: 13th Mar 2009, 23:36 -
1TB Raid?
By CogoSWSDS in forum ComputerReplies: 8Last Post: 30th Sep 2008, 08:35 -
Is Raid 1 always this slow?
By gary11364 in forum ComputerReplies: 7Last Post: 5th Aug 2008, 21:23
