Hi everyone,
My tradidional way of converting Divx / Xvid files has been splitting the audio and video in VirtualDUB (wav) then converting both files together into one Mpg using TMPGENc.
I was just wondering, is there any program that can convert such files, without having to split the audio/video first?
The reason I have always de-multiplexed the files is to avoid common audio/video sync problems. Only problem is it takes too much time, hdd space and makes batch processing difficult.
Any advice would be very much appreciated
Many thanks
Clint
Yep, Tmpgenc will do it. But you do risk sync problems. esp if the divx contains VBR audio.
All you have to do is extract the audio to a wav file. No need to save the video with no audio too, just use the original avi as video source and the extracted wav file as audio source.
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
Mac audio program similar to BeSweet?
By bgart13 in forum MacReplies: 2Last Post: 26th Jan 2011, 05:44 -
Tool similar to TMPGEnc DVDAuthor that can handle DTS audio
By robertazimmerman in forum Authoring (DVD)Replies: 6Last Post: 12th Jan 2011, 11:45 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
