Thats the problem, the Composite leads with the 3 coloured plugs are useless and were designed for Camcorders years ago, picture quality is pretty poor for a start, and the NTSC color signal cant be processed with them.ok not sure what everythin is but i use a cable with 3 plug (red, yellow and white) and plug them into the front of my tv in the AV2 IN port or the other way is with a connector that goes in the back of the tv
The connector that goes in the back of the TV, what is it?
Is it an RF lead, like a usual TV aerial lead or is it a Scart lead which would be a large black cable, with 21pins at each end.
Results 31 to 42 of 42
Originally Posted by Martyn1980
the connector i use is a adapter where i can plug the 3 coluored plugs into and then the plug goes in the back of the tv -
An extract from that bottom link I gave you (which you obviously didnt read..........)
Other hack posted by domden, May 11 2003:
NO COLOUR PROB,S
IF YOU ARE HAVING PROB,S WITH REGION 1 DVDS PLAYING IN BLACK & WHITE JUST USE A FULLY WIRED SCART LEAD (FULLY WIRED NOT THE CHEEP CRAP) AND SET YOUR PLAYER TO R G B IN THE VIDEO OUT MENU . HEY PRESTO YOU HAVE COLOUR !!!! . THIS PROCESS WILL WORK ON ALL PLAYERS WITH THIS PROB . IF THIS DON'T WORK THEN BUY A DECINT TV AND STOP TRYING TO USE STATE OF THE ART DVD PLAYER WITH A RELIC TV . -
Squid, Monzie is right, you have to ditch those leads, they are very shit quality, you will have to get a decent Scart lead, apart from sorting the colour, it will also improve the picture quite a bit, bye bye jaggies.
You can get a decent one from most hardware places, Maplin aren't bad, expect to pay £5 - £10 quick for a basis one, mines is £50, but im quite fussy.
Its up to you whether its easier to re-encode it to PAL, or you'd rather buy a new cable, but if your gonna get any more NTSC films, then id invest a bit of cash.
www.richersounds.com
They have some really nice SCART leads there.
http://www.richersounds.com/index.php?f=itemdetl.php&p=42460
Or:
http://www.richersounds.com/index.php?f=itemdetl.php&p=201659
Cobra -
ok thanks guys i'll try that
the only other thing is how i access the video out menu on my player? -
If it's anything like my Pioneer, you:
- Get to the idle screen (no disc)
- Press "Setup"
- Go to "Initial Settings"
You should be able to get to it from there. Failing that, take a look in the manual or explore the player for yourself. -
Yep, Richer Sounds is a good choice, especially the Cambrided Audio ones, that second one looks to nice too hide behind a TV.
My whole setup is from Richer Sounds, apart from the TV, im like a kid in a sweet shop in there.
Yeah there should be some sort of Video out or display options, i would just mess about until you find it, you cant really do any harm.
UPDATE!!
Jst to let u guys know i bought a SCART lead set-up my player on RGB and i now have a full colour ntsc dvd!
Thanks for all your help guys! Much appricated!!!
Originally Posted by Squid_uk
It isnt just NTSC DVDs which will benefit. Try out any PAL DVD you are familiar with, and I'll bet you find there is a stunning improvement in quality...
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
