I've been following SatStorm's guide on how to convert to ntsc to pal
https://www.videohelp.com/forum/viewtopic.php?t=209166&postdays=0&postorder=asc&start=0
But when I get to step 12 TMPG won't recognize the dummy vbr file I created in VirtualDub...."File Not recognized" it says.
[/url]
Results 1 to 12 of 12
Go into Virtualdub folder. There you should see a folder called 'aviproxy'.
click on proxy-on.reg. Quoting from the readme, this is what it does >
".... The AVIFile handler included with VirtualDub 1.3b is capable
of running in Proxy mode -- that is, you can install it as the
*default* handler for AVI files, and it will work with signposts
that are renamed to the AVI extension. This means that
applications which previously failed with the AVIFile handler
because of the .VDR extension can now be used, provided that
the .VDR files are renamed to the .AVI extension...."
Now rename your extensions from .vdr to .avi
This should now load ok into TMPGenc. -
I took it for granted (should never do this!) that you have installed frame client support >
click on auxsetup.exe > install handler.
You have done this right? -
Frameserving through virtualdub in achieved by >
load avi > start frame server > click start > save <filename> .vdr or .avi
then load this into TMPGenc.
Just in case you were doing it wrong. -
deckard8
Thanks for all your detailed replies.
I just simply followed the guide and loaded the AVI file into VirtualDun and then selected 'Start Frame Server' and saved it as a vdr file and tried to open that file from TMPGenc.
I hadn't installed client support and i'll also check the 'aviproxy' tonight (i'm at work at the moment).
Many Thanks -
You might also want to have a read of the Virtualdub frameserver documentation at http://www.virtualdub.org/docs_frameserver
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Cheers, Jim
My DVDLab Guides -
If you guys are still having problems look here; https://www.videohelp.com/tmpgenc.htm#problems. Also keep in mind that TMPG doesn't like files with long names or files that are buried in a mountain of folders. Keep it simple (i.e. C:/videos/my.avi).
It doesn't matter who you vote for. The government always gets in. -
What variant and version of virtualdub are you using ? There seems to be an issue with frameserving in the 1.4.10 release
Read my blog here.
vcl file frame serve for avisynth
By norlane in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 02:20 -
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 03:12 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 15:05 -
increase the frame width with virtualdub?
By sharmine in forum Video ConversionReplies: 3Last Post: 17th Sep 2007, 18:17 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 13:28
