To clear some space on my hard drive I burned some avi files to CDR disc. Now I want to put those files back on the hard drive in order to convert and burn to DVD-R.
I know I can play the dat file in the MPEGAV folder, but do I need any of the other folders/files?
How do I put what was once an AVI file, but is now a collection of folders and files (with no avi extension to be found) back on my hard drive?
Did you forget that you converted the avi files to mpeg1 and made a vcd out of them? Some people say just rename the dat to mpg but I think the file header will still be wrong even though it will play fine. There was a freeware program floating around at one time called dat2mpg. Don't know if it's still around but look for it. There is no real advantage in converting the files back to avi. Although the file size may be smaller as a divx you could end up with poor video due to the dual conversion.
btw) Depending on certain video and audio properties you can make dvd's out of your mpeg1 -
VCDGear is the way to go from VCD back to mpg. But you'll never get your old AVIs back without reencoding the mpegs to AVI, thus losing quality.
/Mats
Won't recognize disc
By totallylost1 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jul 2011, 18:57 -
Pioneer DVR 520-H does not recognize disc
By Steve_Rbts in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Sep 2010, 23:35 -
Vegas 8.0 8.1-64bits & 9 don't recognize .m4a
By kenwc in forum EditingReplies: 3Last Post: 27th Sep 2009, 22:37 -
Stop motion softwares don't recognize capture card
By Greycat in forum Capturing and VCRReplies: 4Last Post: 26th Jul 2009, 18:22 -
PC drive does not recognize DVD-Video disc
By niko84 in forum Software PlayingReplies: 4Last Post: 17th Sep 2007, 19:44
