Guys got a wav file that I need to delete the first 5 minutes of it. Using Gold Wave and still cant figure out how to do it. Im sure its simple but im lost.
There are two markers, select the Start and End of what you want to remove and then simply Delete it and re-save (better to a different name) the file.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Perhaps there is no delete menu function or toolbar key. Just select the part - as already described - and press the delete key on your keyboard.
The more I learn, the more I come to realize how little it is I know. -
Use left mouse button to set left marker and right button to set the right marker. Then, choose either DEL or TRIM depending on your selection, save the file with different name just in case you are not happy with the results.... Good luck.
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 20:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Help, I think I am going crazy
By pfxz in forum Off topicReplies: 6Last Post: 3rd Aug 2008, 10:17 -
going crazy with editors
By ellabbs in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 12:06 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 02:25
