I did a search but couldn't find anything to help me out really.
TIA
-G
Results 1 to 9 of 9
1) Use MacTheRipper in TITLE/CHAPTER mode to extract the title you want (the one with MF in its name is usually the main feature).
2) Use DVD converter (part of the MPEG2Works suite of tools) to convert the VOB from NTSC to PAL.
3) Use Sizzle or DVD Studio Pro to master a new DVD, and then burn to DVD-R.
If you're in Europe, or in most PAL countries, you should be able to switch your DVD player to NTSC mode in its system menu, allowing you to play NTSC DVDs without this troubling conversion process.
[Edit] Removed unnecessary step 3, thanks Serbian . . . [/Edit]I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Just one note...DVD Converter will produce .m2v, .mp2 or .ac3 and .mpg files...So You can go to step 4) from 2)...
Thanks a lot guys.
How about from PAL to NTSC...I had a spurt of dyslexia for a sec cause that's really what I need to do...sorry. -
Originally Posted by SERBIAN
Originally Posted by xjeffxIf it isn't broken, take it apart and find out why.
blog: deadsierra -
blog: deadsierra
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
screenshots for PAL DVDs (VOB files)--need frame info + step feature
By ezu0526 in forum Software PlayingReplies: 0Last Post: 8th Jun 2007, 15:06 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
