I bought the Toshiba SD-K740 from Costco the other day. It looks pretty much the same as the 3960 model but I can't find a working hack for either model to make it region free.
I've played around with it quite a bit and it does play PAL dvds if I change the IFO files to say NTSC instead of PAL. So, it does have a converter built in. I took the cover off and it has the popular Zoran Vaddis 6 chip. I don't really want to sit here for days trying to figure out the secret code.
Anybody have any ideas? I would greatly appreciate any clues as to where to begin.
You probably cannot.
How do people figure out the sequence of numbers to hit to disable the region protection scheme? Not just off the internet but for themselves.
Can anyone help me to hack Toshiba SD7300, please?
By wertiouy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Nov 2011, 14:45 -
Toshiba DBX3100KE Region Hack
By GREN4 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jul 2011, 18:03 -
Toshiba LCD/DVD Hack
By mebrat in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 10:55 -
Hack for the Toshiba portable DVD player SDP94S
By Charlot in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Mar 2011, 16:34 -
Need Help: Region Hack for DVD Player Toshiba SD-6100KU Thanks
By Panchogun in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Nov 2008, 12:40
