Hi ,
I have a few *.mpg files that I would like to join into one file, I have virtualdub and it works great for joining *.avi files but when i tried it for *.mpg files it will open the first *.mpg file , but then I dont have an option to append *.mpg segment, I have append *.avi segment but it is greyed out, maybe because the original file was an *.mpg to begin with. Or does virtualdub not hanldle *.mpg files to begin with, any help or ideas would be great .
thanks in advance,
dosie.
You can use TMPGEnc to do this. Launch it, and close the wizard. Go to File --> MPEG Tools.
Sorted.
Cobra
Join multiple series of mpg files?
By Chasden in forum Newbie / General discussionsReplies: 17Last Post: 18th Sep 2014, 05:43 -
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08 -
need to join mpg clips
By volam1 in forum EditingReplies: 9Last Post: 23rd Nov 2009, 12:21 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
Join 18 .avi files with VirtualDub
By nlec in forum EditingReplies: 8Last Post: 16th Jun 2007, 00:32
