hi,
i have a Ti4200 with vivo and want to use full screen video through the tv out, when i choose the option in the advanced settings and play a video on my computer monitor all i get on the tv is flickering white and black lines with no picture at all, but when i set the video standare to ntsc i get a picture but black and white oviously because the tv is pal only
ps everything else works in pal mode
anyone have any ideas on how to make it work correctly with pal ?
Your Nickname Was Never Ace, Maby Ace Hole
which drivers are u using? i had similar prob w/ 61.77 and 61.76, but not earlier drivers.
hi
sorry for the long time in writing back, iv been very busy
im using the lastest drivers, i didnt have a problem with the older drivers but i do not want to go back to older versions because i use the card for gaming and like the preformace boost from lastest drivers
also tvtool did not make any difference
anymore ideas ??Your Nickname Was Never Ace, Maby Ace Hole -
Oct 12, 2004:
I had the same problem with 61.77 drivers (when "upgrading" from 53.03), and fixed it by uninstalling from add/remove from control panel, then going to this site:
http://downloads.guru3d.com/download.php?id=10
They have many older versions of the drivers, I went for the last version that had microsoft whql certification:
ForceWare 61.72 Windows 2000/XP WHQL
So you get new drivers that work, are certified, and aren't so much older than latest 61.77. I'm happy now, hope it works for you too.
No need for nvidia drivers?
By A Traveller in forum LinuxReplies: 27Last Post: 7th Dec 2011, 13:06 -
Nvidia latest drivers giving me problems?
By Immortal25 in forum ComputerReplies: 7Last Post: 26th Nov 2007, 20:37 -
PCLinuxOS 2007: Problems with my Nvidia graphics card
By FulciLives in forum LinuxReplies: 24Last Post: 1st Aug 2007, 17:37 -
TV out using 7900 GS (nvidia)
By SignedupGuest in forum Newbie / General discussionsReplies: 7Last Post: 29th Jul 2007, 09:46 -
Nvidia 6800 GT Video Card Problems
By theyuw in forum ComputerReplies: 12Last Post: 2nd Jul 2007, 19:54
