I have an Intel motherboard and have always wondered if the Intel Application Accerlerator does any good, in comparison with just keeping DMA 5 settings.
When Intel Application Accelerator is installed, DMA 5 settings don't show up.
Has anyone confirmed that the Intel Application Accelerator really does any good?
I Appreciate All Responses.
Bruce
Ugh, that thing absolutely froze up my system so I won't touch it. Although it may not have been recommended for my chipset and configuration. If it specifically states it will work with your setup then give it a try. I've heard some good things about it.
Mine shows current transfer mode as UDMA-5. I like the program but it does have to match you chipset. -
Sorry, can't seem to get the image loaded but it does indicate the transfer mode for every drive (both possible and actual).
Mine, too, shows UDMA-5. Without it, I drop frames, so I have to have it. I don't think the DMA setting shows up in the drive "Properties" (as Windows XP enables DMA by default if drives and ide cables support it), but it is in the Intel Accelerator Dialog (when you click the Intel Accelerator icon).
If it works, don't fix it. -
It is my understanding that APP Accelerator enables DMA in the chipset (if it needs too) and in the operating system (if it needs to). I figure "who knows an Intel Chipset better than Intel".
Name of Application
By PC_Tek in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2010, 15:54 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 10:42 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 00:19 -
Do you know the best free download accelerator and manager?
By coody in forum ComputerReplies: 2Last Post: 23rd Jan 2009, 22:02
