hi all,
i'm trying to create a menu with video thumbnails with motion video but when i render the menu out i just get an 'error os......' something or other and it dont work. if i deselect 'animate buttons' and just have a still image for each thumbnail, it works absolutely fine, the buttons highlight and select and play their respective chapters. but as soon as i select 'animate buttons', the motion render fails everytime. before i was getting the 'error os(series of numbers)' i was getting 'error setting highlight' and sometimes i got 'error setting subpicture' but since i upgraded from encore 1.0 to 1.0.1 i now just get the 'error os...' message?
any guesses much appreciated.
steve.
A couple of minutes spent in the Adobe Encore support forum found this
http://www.adobeforums.com/cgi-bin/webx?50@19.kmA9cHhh8o4.2@.3bb5e0e7
and this
http://www.adobeforums.com/cgi-bin/webx?50@19.kmA9cHhh8o4.8@.3bb4b03e
And there is probably more, as motion menus seem to be buggy as hell in Encore. You should also consider upgrading to 1.5, although that still seems to have issues with motion menus.Read my blog here.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Encore CS5 keeps re-encoding my motion menu - help!
By Killer3737 in forum Authoring (Blu-ray)Replies: 1Last Post: 31st Jan 2012, 13:52 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 23:17 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
