hi im new to all this ive learnt decent amount but ok heres my question I have a .AVI and when i burn it to a DVD+R and play it on my dvdplayer the movie is like really tiny like theres more black bars above and below them then there is movie is there a way to resize this? or no? movie is fine just like shrunk but on my pc it plays just fine.
You need to supply a little more info, what software are you using and what format are you using to burn the movie (e.g. DVD compliant, divx....).
well when i burn the .avi i use WinDVD Creator which is probably a worthless program but it came with pc, and its .AVI soo im not sure if its divx or wut
That looks like it's a DVD compliant program only soooo.... Two reasons why it would do that. If you specified 16:9 or widescreen when you captured or along the editing or authoring process it will display widescreen which will give you the black bars on a normal TV, just like a widscreen store bought DVD.
Since it displays correctly on your computer I'd look in the display settings of your standalone DVD player. Your DVD palyer will letterbox it (black bars) if you specify it in the menu if it has that option. Try selecting normal as the output. -
thnx i found a way i used WinAVI to convert to DVD and told it to use 16:9 works awesomely
If in doubt, Google it.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
