ok i just got a burner... tips i got was get DVD clone, decrypter, shrink. then Decrypt , shrink, hitback up and then i should be set. so i decyrpted a dvd saved it to a folder then shrunk it and hit back up and now the folder i saved it to in the begining there is 4 different types of files
2 BUP
1 ABM
7 VOB
3 IFO
now i tried to burn it with the decrypter and none of these files are reconized or whatever , i dont even know whats the movie are what.
a link to a helpful easy to understand guide or someone with patinence and knows how to explain this easy would be very very appreciated.
Thanx
JD
Use this guide to rip the files to your Hard Drive
Use this guide to feed the files into DVDShrink - output to an ISO Image and burn with DVDDecrypterIf in doubt, Google it. -
BTW, take a look through the All Guides section over there <===== and you'll find heaps of guides
quick question... it says put dvd in dvd drive i have and external dvd writer does it mean the writer or my Rom... may sound stupid haha
Put blank media in the external writer to burn, either to ripOriginally Posted by jxD
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
DVD Burner
By jason in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 16:02 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
