I'm getting this error everytime i want to capture by scene, "Data/time recorded was not found on tape" i can capture the whole video in one piece but not by scenes, anyone one if i can fix this? im using adobe premier pro 1.5.
Looks like the time code has become corrupt. This can happen if you stop recording, rewind for a look see, then start recording again after the previous scene and also after the previous timecode. There isn't much you can do other than to capture the whole thing and cut it up in premiere. You could try one of the small capture apps like DVIO and WinDV before giving up. They mau have better luck.
Next time, when you open a new tape, record across the whole tape in one session with the lens cap on. This will lay a timecode down on the whole tape so this doesn't happen again.Read my blog here.
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 16:43 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
error message when capturing from Hi 8 Camcorder to PC via the capture devi
By mcreigh in forum Capturing and VCRReplies: 3Last Post: 29th Oct 2007, 16:51 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
