Can anyone tell me if such a upgrade is out there and where I might be able to find it
it would sure help if you said what model -- but i'll just guess anyway
General Comments:
I contacted Orion who support the SANSUI recorder. Below are my questions and their response:
My Question 1) Has there been a firmware update for the VRDVD4005? If not, will there be one?
Orion's Answer to 1). There is no firmware update for the VRDVD4005. Our techs tell us that none is needed. Some brands of the blank discs have an insert with a warning & mentioning a firmware update being needed for some machines. This is in regard to the capable write speed of the disc & the write speed of the recorder. Our machine records at real time only (1X) so that is not an issue.
My Question 2) Do you know how I can play multi-region DVDs on the unit?
Orion's Answer to 2). Our unit is designed to play region 1 disc only. Please be advised that Federal Regulations require that these units be manufactured with a specified region applied. This provides some protection to the movie industry copyright laws. We do not provide a method to override this feature.
My Question 3) Is there a punch code on the remote that will allow more settings for additional configuration of the unit?
Orion's Answer to 3). There is no punch code that will allow for more settings for additional configuration of the unit? There might be a model later this year that will have additional features but that will be a different model number.
My Question 4) Is there a possibility of SANSUI updating the firmware to allow permitting DVD+RW & DVD+R recording?
Orion's Answer to 4). There are no plans at this time for updating the firmware to allow permitting DVD+RW & DVD+R recording?
Answers are from:
Customer Servcie Admin.
custsvc@orionamerica.com
Thank you for contacting Orion Sales, Inc."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
and another model
http://shincodvd.emuunlim.com/firmware.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
and another model
Tuohon aikaisempaan Sansui DV-X3000 käsittelevään viestiketjuun kun ei jostain syystä pystynyt enää vastaamaan jouduin sitten aloittamaan uuden.
Haaveena olisi saada päivitettyä soittimen firmware, mutta tästä vekottimesta kun ei juurikaan mistään tietoa löydy niin toistaiseksi on päivitys saanut jäädä. Onkohan kukaan kyseisen mallin omistaja saanut päivitettyä rakkineen firmwaren?
Plärättyäni ankarasti satoja sivuja törmäsin Shinco DVD Info sivustoon jossa mainittiin Sansuin malli 2100 josta päättelin että tämä 3000-mallikin lienee Shinco-pohjainen soitin...
Ainakin lukuisiin Shincon soittimiin löytyi firmware patch jotka mm. lisäävät Shincon soittimiin Macrovisionin päälle/pois asetuksen. Sansui 3000 tuolla ei mainita halaistua sanaakaan eikä tosiaan juuri missään muuallakaan.
3000 kun on varsin kranttu DVD+R levyille (vain muutamat harvat mallit pelittävät) olisi kiva tietää mahtaako soittimen firmware-päivitys korjata ongelman.
Kurkkasinpa soittimen sisuksiin siinä toivossa että jotain paljastavaa sieltä löytyisi. Soitin on kasattu kiinassa joka vahvisti uskoa että Shincon pajalta olisi tämäkin lähtöisin. Sisuksista löytyi muutamia MediaTekin piirejä esm: MT1336E (DVD-Player RF-Amplifier) ja MT1369FE. EEPROM on puolestaan Atmel AT49F8192AF
Lisäksi löytyi Aimtron AT5654H chip. TV Encoder puolestaan on CS4955"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
and something else
1.Turn ON the dvd(WITHOUT DVD INSIDE!!!)
2.Press PAUSE on the remote control.
3. Press 3,1,4,1,5,9
4. Press 0(zero) (it mean moltizone)
5. Press PAUSE again.
6.Trun OFF the DVD .
7.ENJOY!!!"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 03:45 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 00:33
