i'm following the tutorial on converting divx to DVD. i'm concerned about the part saying the you can get audio sync problems when converting divx/xvid etc. i've outputted the movie's audio file using virtual dub (as per the instructions) but will this prevent audio sync problems? I don't really want to have to leave the computer for 3 hours converting only to find there's a sync problem.
can anyone advise me on this?
It usually helps to prevent audio synch problems if you convert that way. You can always a five minute portion to see if it has synch problems before encoding the entire file.
Hello.
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 20:29
