I am trying to backup a tv show for my kids (i like them to watch backups so not to trash good purchased disks)
Here is my problem
The disk comprises of 6 episodes on 2 disks (3 a disk)
I normally use dvd shrink and can easily rip the first 2 eps onto a disk without too much compression. how can i take the 3rd episode off one disk and the first off the 2nd disk. and merge them together into a playable dvd.
I could esisly do the following but it is a waste of disks.
disk 1 - 2 eps
disk 2 - 1 eps
disk 3 - 1 eps
disk 4 - 2 eps
as you can see that is a waste of disks
I would like to get
disk 1 - 2 eps
disk 2 - 2 eps
disk 3 - 2 eps
Hope that makes sense
LLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
---Monty Pythons Flying Circus -
I know i can do that but the problem i have is that eps 3 and 4 are on two seperate dvd's and i want to put them onto one
you can still do it with DVDShrink but you lose menus
http://www.dvdshrink.info/compilation.php -
I just downloaded the latest DVDshrink 3.2 as my old version would not do it.
however when i try and rip the disk i get a copy protection error any sugestions?LLAP-Goch... the secret Welsh ART of SELFDEFENCE that requires no INTELLIGENCE, STRENGTH or PHYSICAL courage
acully i found the problem. it was looking for nero no idea why since i was only ripping unchecked the burn with nero option that was messing with it
Problems with ISO file backup from HDD to HDD
By badboytim999 in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2011, 09:03 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2009, 00:36 -
Problems with large (1 Tb) USB backup drives on older computers
By Toastie in forum Media Center PC / MediaCentersReplies: 10Last Post: 30th Apr 2009, 03:40 -
Space Chimps backup problems
By HmNtr in forum DVD RippingReplies: 3Last Post: 19th Dec 2008, 16:20 -
dvd backup problems
By RemainsHuman01 in forum DVD RippingReplies: 1Last Post: 20th Aug 2008, 01:15
