just wondering as I can't find an answer elsewhere on the forum if it's possible to somehow do something with the audio from a divx/xvid file so that the sound is 5.1 or near to when converted to a dvd?
if the divx has ac3(5.1) sound then just extract the ac3 using virtualdubmod and then use an authoring program that can accept ac3 audio like dvdlab. thats how I handle it. if the original divx doesnt have 5.1 I dont mess w/ it trying to create it, but Im sure somebody will chime in who does.
If you are not converting the video format then it is very easy. Just demux the audio using VirtualDub. If you are changing the framerate of the video then that is a different story.
Make sure you run ac3fix on the extracted ac3 file, Vdub likes to put useless header info in the ac3 stream which makes it non-compliant.
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 18:12 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 13:56 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 17:48 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 07:02
