While backing up a dvd movie, I can preview the movie as well as menus and Extras in the preview window. Noticed on a couple movies that there was NO sound on some of the extras. Video was just fine. Go to PowerDVD and play the dvd and the sound is there on the extras. Burn the backup to DVD+R and as in the preview window, no sound on Extras. Any ideas? I use Recode but figured I would try Shrink to see if any difference. No sound there too... only does it on certain movies. Help?![]()
LawnCowboy,
Sounds like too many of the Audio Files are being disabled.
Check your settings in both programs.
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
nothing disabled... trying to play em right after the analysis. Dolby 5.1 and 2 channel are selected..
LawnCowboy,
Try this in DVD Shrink:
After Analysis open the Extra in the Preview window.
When it starts playing right click on the Preview window and choose "Audio" from the pop-up menu. Does it show any audio streams ??
You can see a graphic on this guide:
http://www.doom9.org/index.html?/mpg/dvdshrink31-main.htm
If it doesn't show the necessary audio Streams then you'll need to adjust your preferences.
See here - http://www.doom9.org/index.html?/mpg/dvdshrink31-main.htm
Hope this helps,
Thanks Moonstomp.. I did what ya said and it works as well for Recode... guess 5.1 was selected when extras are usually 2 channel... have to try it after recorded. don't know why certain ones do that when others select the right audio track by default... thanks again...
LawnCowboy -
Congrats !!
Glad to hear it worked and to have been of assistanvce - that's what this Forum / Site is all about !!
Happy Backing-Up Cowboy.
Cheers,
Nero 9 Recode - DVD audio error
By ringo12 in forum Video ConversionReplies: 3Last Post: 22nd Nov 2009, 17:39 -
Join 2 MP4s made by Nero Recode 4 (and Preserve 2x Audio; 2x Subs)
By GrayStrickland in forum EditingReplies: 1Last Post: 16th Feb 2009, 04:09 -
playback stutter on recode and dvdshrink, none on vlc, nero showtime etc
By RdM642 in forum DVD RippingReplies: 4Last Post: 15th Feb 2008, 12:15 -
DvdShrink, Recode Bug
By FallenAngel10 in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 22:58 -
Nero Recode and 44.1kHz audio
By rindless in forum Portable VideoReplies: 2Last Post: 6th May 2007, 14:16
