All my blank cds hold 650mbs and I need to squeeze a bit more divx footage onto it. What's the best way to go about this and maintaining as much quality as possible? Thanks
You could use VirtualDub to chop the credits off, or recompress the video.
Buy CDRs that will hold more data, I use 99min (870mb) cdrs. You may be able to make do with 80 min (700mb) cdrs.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Use a burner with HD burn and get over a gig onto one cd.
All of the answers you get, you may not like. CD's are so cheap now-a-days that buying a 700mb disc is sometimes free ar. -
Do you need special softwares to burn oversized CD-Rs? Or would Nero do the job?Originally Posted by VCDHunter
I'm a nobody, and nobody's perfect...so I'm perfect! -
Nero, when setup correctly, will burn these just fine.
I was just hoping as my movie just goes over the cd size that perhaps there might be some way I could compress it. I want to get rid of the amount of cds I have first before buying a bigger size. I don't need to convert it to mpeg either as I can view it through my divx player. I was just wondering if it were possible to reduce the size a bit like you do with dvd shrink
It's no big deal, if there isn't a way I will just have to put it on a dvd or something
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
dvd shrink help
By mikeoliver1313 in forum DVD RippingReplies: 3Last Post: 19th Feb 2008, 10:29 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
